GReddy 18g from a civic si 00'
Got everything in yesterday: FP race mani, Ebay turbine housing, Ebay o2 housing, Greddy 18g, 3'' intake. Install is pretty simple, we got oil from the filter housing using a stainless line. But we ran into a problem, the oil feed port on the turbo is NOT the same size as a 16g or 14b. The banjo bolt needed is the same size as the stock 1g banjo's in the head. luckily we had one of those. Here are some pictures:
So, how is that eBay turbine housing holding up?
My original TD05H turbine housing is cracked and leaking exhaust, quite a PITA.
If I buy one, I'm going to convert it to an external off the O2 housing.
LMK
LMK
That turbo setup is out now and sold, I got a good deal on a 50 trim so I jumped on it. But, when I took the housing off it looked perfect. No cracking or anything. However, the wastegate hole on the ebay housing is tiny, even though im pretty sure it's a 34mm flapper. The small hole made it impossible to run anything less than 22psi, which was fine for me. So if you're going to run a external off the 02 i would highly suggest opening the wastegate hole a bit...
