Got good fuel/spark/compression still no start
yeah I have dsmlink but its not reading the coolant temp, never heard of a bad coolant sensor preventing the car from starting, makes sense though. Ill get that taken care first and let you know if thats the cause of the problem...thanks
That did the trick, the wire harness to the coolant temp sensor was disconnected. Never would of known that was the cause of the problem. You guys rock thanks :rocks:
I've never heard of the coolant sensor stopping the engine from starting either. Thats kinda crazy but it does make sense.
How sure are you that the timing is dead on?
There are two forms of timing, ignition and cam. The ignition timing on a 95 with an original engine is fixed. Cam timing requires you to rotate the engine to TDC and check all the timing marks at the crank, oil pump, and cam sprockets. If all the marks line up it's correct.
I agree with this, just want to make sure that the OP is sure of it. Normally when I see this problem the timing is one to two teeth off.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
