Spark, Compression, and Fuel but no start?
AK_4g63t
100
Apr 21, 2007
Fairbanks, Alaska
So yet another no start issue to add to this site. I drove my car into my shop and pulled the motor because of new timing pullys, belt, covers and also had new clutch components. I put the motor back in and suddonly it will not start. Ive got around 180 for all cylinders (9:1 pistons) as far as compression goes. I have fuel at the fuel rail and I have spark on all spark plugs. I used my ignition tester to test all spark plugs. I pulled the plugs and theyre dry and have no signs of any damage. I used my multimeter and all injectors are firing. Im going to pull it in after work today and clean up all my grounds and see if that helps. What sensors are needed in order for my car to start? When my timing cover was off I cleaned my crankshaft and cam sensors with a rag and some brake clean on it. I was really carefull about it. I dont have dsmlink or anything to check out any data. Timing is correct. Any suggestions?
Alright, I used my matco scanner and here's what I have going on. I have the ECT as 63 degrees and the intake temp sensor is at 73 degrees. At rest and cranking its showing it's sitting at 5 degrees advanged. Im getting DTC P0202D for injector 2 circuit malfunction but that would cause cylinder 2 to be dead and my car to atleast start but run terrible.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
