Good or Bad Logs
mattp_65
Supporting Member
528
187
Aug 16, 2004
Granite Falls, Washington
I was just wondering if these logs are ok. I think I have some knock on each log, what should I do add some more fuel or turn down boost?
The 1st log is at 17.5 PSI, 2nd log at 18 PSI, 3rd at 15 PSI:
Thanks
Where should the timing be at WOT? I will check my high settings but I think it is around (neg) -30 because of the 660's. Before the cams it was ok now after the timing dip a couple of times.
thanks
