going t4... need input on proper combination
Mark S.
85
Aug 21, 2003
I just got a new t4 manifold and am planning on going t4 with my setup. I've been looking at t4 60-1 setups (mostly turbonetics setups from agp). I have all the proper supporting mods (I went 12.000 at 115 on my 16g). Fully built engine, small bit of head work, mild cams, 780cc pte injectors, dsmlink, maft...etc etc. I want a turbo that is going to be able to put down 400+ hp on pump gas and just be ridiculous on race gas. I know the 60-1 is a fantastic high boost racegas turbo... my buddy put down 495 hp on a basically stock engine with one. I was looking at agp's website and under the to4e turbo section theres a whole different variety of compressor wheels to choose from. I was intrigued by the the super 57 trim(basically a normal 57 trim comp wheel with a .2 inch larger exducer) I was wondering if anybody has had any experiance or input on any of these "super" turbonetics wheels. Also being t4, my turbine housing a/r selection is almost unlimited. I would probably go with the .68 a/r but if someone has a magical combo of a/r and compressor wheel let me know.
Are there any specific reasons for this? Do you have experiance with this combo? How does it fare on pump gas and on race gas? Spool times?
i converted my scm-61 to a T4 setup using an AR .70 TH with a P trim.... this turbo get a full boost around +-5300rpm at 25psi. I love this turbo and it give me more control on the launching since my car is FWD... i'm running with pump gas and never try it on racing fuel yet.
what wheel you intend to use with the AR .68 TH..... for stage V maybe it around 4-4.5k but if you use P trim it maybe later around 500rpm with the extra power on top....
Mark S. said:
I'm looking for something moe in the 60-1 range spool wise. 4k-4.5k ish...
You'll need to stay with the t350 to keep spool where you want it. Either the 60-1 or the 56 trim 61 will do fine. I would opt for the 61 if I were you though, but it may fall out of your spool requests. ####, just throw on a 67 :D
