h1e,hx40 combination
That wheels looks to be the 60mm 6 blade wheel. First off that compressor cover will not work as that is held on by a huge c clip and your H1E is held on by a vband. Secondly your chra must be able to accept the exducer of that wheel. Not all are the same and some need some machining. It seems like that wheel would fit in the bigger HX40 60mm 7 blade chra. Im sure someone else will chime in soon enough but that won't work with the idea your running with.
ok thanks for the quick reply, im just trying to figure out what to do. I reallly want to run this h1e, but i was a idiot and bought out of impulse without reading the fine print. Ill figure something out
If your H1E has a 60mm inducer, any 6-blade or 7-blade H1E / HX40 compressor should fit. If your H1E has a 58mm inducer, you're stuck using the 58mm 8-blade wheel.
Just so you know, when you're done, you'll still have a H1E. The model refers to the series of housings used, not what wheels are inside. Many H1C's share HX35 rotating assemblies, as do many H1E's share HX40 assemblies.
Is that guy's listing for real? The wheel is machined from SOLID TITANIUM? Perhaps he should go back to 10th Grade Chemistry and study the Periodic Table a little more. If that wheel were solid Titanium it would be selling for $1200 and weigh as much as an empty soda can.
Instead of buying a wheel with a cover you can't use, why not pick this up for half the price? Sure it's aftermarket, but so are 99% of the Holset parts on eBay.
hell yeah thanks for the reply..you will also be getting a pm when its time for the rebuild....but i should ask you first. I have the turbo in pieces bc i wanted to inspect the wheel. If i send you the pieces can you figure it out LOL
