Gm Maf install question
JayB12
544
Jan 12, 2009
Philipsburg, Pennsylvania
I run my car with a safc tune/stock maf ATM, I'm installing a gm maf and translator very soon and I was wondering if it's just plug and play. And if it will affect my safc tune. Also can you run a gm maf and maf translator with the ceddymod? I'm going to do that as soon as I get a new laptop.
You can run the GM MAF with the translator (and ditch the SAFC since it's not really needed at that point), or run a GM MAF directly to the ECU if you have EMCLink and one of their GM MAF cables.
so in order to run a gm maf you must have either a safc or a maft? i want to run a gm but dont really wanna spend that kind of money on the safc or maft.
sorry im a rookie. ;)
You need either a MAFT or ECMlink with their GM MAF cable. An SAFC has nothing to do with running a GM MAF.
AWW MAN!! I recently read someone actually threw on a GM MAF without this stuff. All he used was a cable from dsmlink that allows you to plug one end to your factory plug, the other end goes into the GM MAF. I thought with this you can do that and still use anytuning source available such as ceddymods/ecuflash.
