GM maf, i need help
95biotch
30
Mar 16, 2004
dallas, Texas
Hey guys, i have installed the dejon tool blow thru setup pipe and a 3' gm maf in it. At the time i couldnt afford to get the translator, now i have ample amounts of dough. Here's my question, ive been looking through tons of threads and reading how to tune using this setup and i know that you adjust your cars settings with the maf translator but you obviously need something that shopws you what your changes are doing. Im under the impression that this incredible device is called a logger. Correct? To get to the point, what else should i buy to tune with the maf? Thanks -Kyle
Yup, You should really get a datalogger, Especially when trying to make adjustments to the car. :) As long as you have an instrument to see what is going on when you are making you're adjustments, You should be fine. I have the translator and a datalogger.
thanks guys, i got a nice palm off ebay and im buying the thing thats like obdII or something like that. Its $125. I heard when your check engine light comes on you can pretty much fix it yourself with this one. Im pumped.
