GM MAF Help
cdsm25
Oct 23, 2010
Oshkosh, Wisconsin
I need some help on my 1g MAF tunning on ECMlink. Any time the car rev's up off idle it tends to want to die as it returns to idle. I have look for any easy fix's like vac leaks etc. I have been told this is a " 1g thing" that has to do with blow off recirclulation. Any wy to tune that out??
Thanks for the help.
I believe you still need the Maf translator in the car but you set it for 1g with stock injectors and then you tune things in with the ECMLink. I'm positive you then set it in the Maf Comp tab in link. Forgive me if I'm incorrect I haven't looked at v3 in about 6 months. If you have a dsmlink forum name I would search there I remember seeing tons of info on this because I had the same issue. I however resolved it by just switching back to recirc.
I could guess what your problem is or look at your ECMLink settings and figure it out for sure, ones a waste of time and the other might get you somewhere.
:dsm:
