GM 3"& MAFT. Need Tuning Help ASAP
91DSMdave
223
5
Jun 23, 2009
Strattanville, Pennsylvania
1G talon tsi awd.
Ok. So i just bought a 3 inch GM Maf and MAFT. now i need to know what to get it all set to.
stock everything fuelwise, front mount 3 inch pretty much stock. no wideband, or metering system of any kind. I just need to get it set at a ballpark level so the car will run just as good if not better.
From what i have gathered, dip switches are all off and the base knob is to be set at 2. im lost on everything else. Translator is the 2.02
please help me. I have searched and have gotten no clear answer cause most everyone is tuning these for bigger injectors.
thanks ahead.
the instruction tell you everything, but i wouldn't recommend changing it from a stock setting till you have some way to measure knock.
for stock 450cc injectors it should be set aux =0 base =2
the other three adjust airflow calibration for idle/mid/WOT
but every gm maf will read different( at least all mine have) so theres really know correct way to tune it without a logger/ wideband
Yep every car is different, mines are everywhere too, read the directions everything you will need to get started is right there.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
