Getting a TRE tranny.
I've dealt with TRE a lot and they have changed a lot over the years. A lot of complaints about TRE from a few years ago were valid. I must say though, Jon's really turned the place around in the last two years. I just got my tranny back 3000 mi ago with a full rebuild and it went in flawlessly. I've had 0 problems. Now I'm from nearby (within an hour) and I've spent a few days around the shop. Jon had the time to explain why his rebuilds can get to be so expensive. Many of the transmissions come in either broken already or with over 100k on them. TRE wet magnafluxes all gears and shafts to check for stress fractures. When an input or intermediate shaft has a stress fracture in a gear that increases the price of a basic rebuild by over $200 right there. I'm sure he could open up a used tranny, replace all the synchros and replace any bearings that look worn, re-shim the shafts and return the tranny to you for under $1000 but when you start to make some power and shear the teeth off a gear that had some cracks or wear it's going to cost a lot to fix and it won't be a warranty issue. I also know that TRE does a significant amout of work cleaning up the crappy parts that Mitsubishi has been sending out as well as some machining to make shifting better. This isn't something I've just heard but I've seen it on the lathe.
Anyhow, many people have had luck with Shep and BM Tranny and I know I've read posts about tranny problems from both shops too. All I know is that Jon rebuilt my first tranny in '98 for a FWD and it's still shifting and my AWD feels great. I guess the point is that Jon knows what he's doing. He's done over 500 DSM transmissions over the years and if they weren't better than most he wouldn't still be doing them and he wouldn't have repeat business like mine.
To address another note, NO TRANSMISSION IS BULLETPROOF! You put enough torque on something or powershift like a gorilla you will break it! 'nough said. If you have seen the guts of an EVO 8 tranny it looks like an Eaton Truck transmission compared to the crap DSM stuff we got. It seems there is only so much that can be done to a DSM tranny.
To address some of the points Chris made:
Going into this post I will acknowledge that you are an established tuner and that you know a lot about DSMs.
It sounds like a lot of your troubles were due to miscommunication and bad information.
Did your customer send a '90 trans in or did Jon end up thinking a '93 trans was going to be put on a '90 car? If you were using the selector cable brackets it would be almost impossible to put the cable onto the '90 arm. It's much longer than the 92-up style. I don't know how the thing shifted in the first place.
Why would you change out the cables and console if it was TRE's fault? Why not just tell them the selector arm was wrong and have them replace the arm?
How many miles did your customer get on the trans before 3rd went bad?
Was it ever sent back within the 90 warranty period?
The GVR-4 first gear is a stock Mitsu part with a different gear ratio. It makes first gear a little taller. Being a stock part it's no stronger it just has double synchros as an option to shift longer. Nowhere does it say it should be stronger.
Once again with the free fix, was it a warranty repair or just a good will, free labor repair?
I've seen TRE tear down over a dozen tranny's in my presence and it has never taken more than 20 minutes to pull apart a whole tranny just because clearances were tight (probably from NEW PARTS) and you don't have the tranny experience doesn't mean they beat your tranny together and it was stuck.
Anyhow, I'm sorry you had a real bad experience. Anybody can break a tranny though. Pruven ran last season on one TRE tranny without breaking it. I suspect there is a bit of driver skill involved in not destroying your tranns. These are cars, not playthings. If you want to treat them like playthings you will break them. Good luck, get the best deal from whomever you think has it, and have fun.
To answer some of your questions or to better clarify my first post.
The car is a 16G powered car with around 300 HP. Not a very powerful DSM, so too much power is to at all the case.
When I got the car he had been driving it for apart of the winter with the third gear grinding. The car had maybe 3k on the rebuild. The car only makes short trips. When I got it I changed the shifter brackets, cables and console. By changing all components you are exactly mimicking a 90' car. This was an attempt to get the tranny to shift a little better to make it through the winter.
Here is the point. It is great that Jon gives you this warranty but some people actually have to drive their car. This guy drives his car to work everyday and can't afford the time and cost to have the tranny pulled and shipped every time someone else screws up. The car is a 93' and the tranny is a 93'. Jon made the mistake and brushed it off when told about it. I exclusively use Speed Design diffs in all my customers trannys. I know how they come apart. I do enough of them. They are never even remotely as hard to pull apart as this one. Not to mention the mangled diff.
TRE may go over the tranny with a fine toothcomb. That's great. I would rather have Shep build me two trannys for the same price as on of TREs. So when it does break I can change it out right away. Who wants to eat shipping cost, wait two week or two months for that matter? Then get told he should upgrade his tranny to one suitable for a 10 sec. car.
No thanks
Chris
New England Performance Tuning
well off the argueing topic i got my tranny put in and every thing is just about ready to go all i have to do is put fliud in the tranny and transfer case but so far every thing is good besides that this install kicked my ass--- cut up, scracthed up,hit my head a few time and droped the transfer case on my face while under the car but it is just about time to put it on the road would have done it tonight but i got 2 jobs and 3 if u count working on my car but should have it ready to go tom. so i will let every one know how it goes and i hope good later
Gary
Eventhough I have never been a customer of TRE, what I have to say about Jon is that he's a great mentor. He wouldn't hestitate to answer any questions on how to correctly build a reliable tranny and share some of this personal experience on transmissions. Buidling tranny is not simple, especially when it comes to shimming with the proper value. Takes a lot of time and effort. When time and effort are getting no where, TRE was the first one to help me out on desperate situations. I can assure you Sheperd or Mark french wouldn't answer some of the technical questions. Jon knows his stuff off the book. Good luck.
OK people, just installed(30 min ago) the TRE race tranny and one word AWSOME, very good people to deal with and excellent service and awsome tranny. I put 10 miles on it so far and it shifts like butter, will keep you posted...the longer 1st gear is nice too and with double syncro on first can down shift very easy...
well i am have some problems with my TRE tranny i got mine in and it would not shift into 1,3,5 gear so i adjusted the shift cables and it went into 3rd like 3 times but now it just spits it out of third i tried to adjust it more and still nothing so this really sucks i emailed them and he told me to do what i already done now it is the weekend and they r not there so it really sucks i don't know what the problems is but i just don't feel like pulling the tranny back out again. it shifts like butter in all the other gears and 3rd was like butter the time it worked so if any one can help that would be wonderful
yeah i bleed the clutch but jon is working at the shop and he did e-mail me today and said it is the shifter select finger cause of the shift rails or diff in the 90 he said he is going to get me a new shift base and it should f ix it i hope so.
well i have to say that all this stuf about TRE not having good service is crap i am haveing a little trouble with my tranny but jon has been way more than helpful with me. he is helping me out alot and when i email he is geting back to me right away but the car should be tip top soon and i would say that TRE is a good company and i would do buisness with them again.
Me: ACT2600, NITTO 555R drag radials, TRE tranny. Double Synchro 2nd, Upgraded 3/4 gearshaft, Upgraded synchro materials, SS rails, Evo 1/2 and 3/4 shift forks. Butter for 7000 miles, then broke the "unbreakable" 1/2 fork. Disappointed? No.
I'm sending it back to him. Sure I'm poor after the last round, but it takes money to go fast, and money isn't a concern if you want quality. I took 2 seconds off my car since this transmission was installed and it predictably, smoothly and reliably took the abuse that he said it would. I think he does great work. And when there's a failure, he develops stronger and better replacement parts, i.e... EVO Forks. Used to be plastic shimmed, but now Jon uses his own bronze-shimmed design so they don't wear out like mine did. Unfortunately, that weakness was discovered a month after mine was built.
Mitsubishi makes crappy transmissions, period. Look at the number of warranty claims they have across all FWD/AWD Auto/Manual transmission cars. Look at the cause of the losses in WRC... Look at the recalls... Look at why all of them are sitting in junkyards... most of them have blown trannies, great bodies and working engines. Any time you upgrade your engine, you're increasing the likelihood of failures. Mitsu's trannies don't even fare well in a STOCK car. I doubt that anyone can actually build a "bulletproof" transmission out of one. Not Shep, not BM, not TRE, certainly not Mitsubishi.
I got my TRE race tranny back in April. It was awesome. With 550 hp I was able to shift 1-2 at 9000 rpms. I went to the track almost every weekend. After several months of abuse it would no longer shift into second at those extremely high rpms. I sent it back to Jon and the second gear snychros were shot along with the hub and sleeve caused by improper clutch disengagement. It was actually past the 90 day warranty period but all he charged me was $100 dollars for the hub and sleeve. Turn around time was 2 days because I told him that I wanted to go to the shootout. I ended up not making it but it wasn't Jon's fault, he kept his word. When I bought the thing he told me two weeks and that's exactly how long it took. So far he has been very helpful and even e-mailed me to check on the car. I'm sorry if you have had bad experiences with him but Jon has treated me great and his customer service was excellent.
Pic of my TRE race tranny
Jon and Ming @ TRE are awsome people to do business with in my experiences. They have always taken good care of myself and everyone i know that has done business with them. They are very helpful and knowledgable when it comes to anything about a dsm...not just transmissions. The biggest complaint i hear about them is that they can be slow at times...but a quality product can take extra time to produce.
People complain about slow service? I ordered my tranny on monday and the next monday I went to pick it up...what more could you ask for..AWSOME..
