Garrett T3/T4 on stock 4g63?
GoAt
Jul 11, 2011
Ferryville, Wisconsin
Hello, I have a Garrett T3/T4 turbo and I am about to install this to my 98 gsx on a stock motor. What does this turbo put out for stock boost, and I am wondering if this will work or will this detonate my car?
A lot more information on the turbo is needed.
As for boost, I'm guessing it doesn't have an internal wastegate, making boost entirely dependent on the spring in the external wastegate that you're going to need. It will probably be fine on your stock motor as long as you tune for it and have sufficient fuel.
you'd better beef up your fuel delivery, and get DSMLink before you try that..and perhps some supporting mods.....blow it up? no....be unable to spool it and/or run like crap? yes
The boost level is determined by the spring in the wastegate, which is probably too high for the stock fuel system (which is what I assume you mean by stock motor).
What does this turbo put out for stock boost?
I'm assuming you mean how many lb/min will this turbo generate at our car's stock boost level of 10-11psi...as a non-wastegated T04E50 has no way to control boost and will generate as much pressure as the application on which it's installed will allow.
