T3/T4 Garrett ?????
PSSSHHHGSX97
Aug 30, 2005
Coram, New York
I just had my car tuned and it put out 338 HP to the wheels @20PSI. The guy told me I should upgrade my EVO III 16G to a T3/T4 Garrett. He said the car is making awsome power for that EVo III, but this is all Im going to get out of it. How much more power should I be getting out of a T3/T4 ???? is it much better than the EVO ??? Need my true DSM's peeps opinions. Thanks guys :D
Turn the boost up and you will make more power.
Go to bullseyepower.com, there you can get a t3t4 garrett that bolts right up to the mitsu manifold. Also, they cast all their own exhaust turbine housings out of steel instead of iron which makes them much much more durable. They sell the oil feed and drain kit and also have an internal wastegate option that will save you some money. I have a 57 trim w/ a stage 3 turbine wheel i got there and it is awesome! That turbo will support around 500hp to 600hp depending on what mods you have. Basically if you don't already have a new transmission, you are going to need one with this turbo :D
go to www.bullseyepower.com and check out the clearance section, there is a v-trim turbo there for a great price. I have seen this turbo in person and it is just fine. That turbo spools quickly and can support as much power as you can throw at your motor without building the block.
"so What would you reccommend for the next upgrade turbo???"
I'm not saying you won't notice any difference at all with the upgrade to the hybrid, but it's not going to be HUGE! I really don't know all too much about your next best upgrade, but if your looking for more of a top end enhancement, have you thought about cams? It's a long shot, but hey! :thumb:
Chris:laser:
EDIT: Scratch that, I didn't see the cams listed in your vehicle profile.
I'm clueless. :shhh:
