garrett 3076 turbo?
what does your head consist of? Higher profile cams slow spool, so they would be a factor in your spool time.
Sup LAZY,
A Gt3076 is a very common turbo, in a dsm style flange it is basically the same as a FP3052. Maybe you should check out the timeslips, and dyno sheet section?
Expect full boost in the 4000rpm range, and a well setup car can make 500whp on them.
Sup LAZY,
LAZY?? how am i lazy? LOL
i tried looking for a video and no luck where it shows it hits boost niether a dyno video..
if you find a slip or dyno sheet please let me know:thumb::thumb:
and this is going on my 4g63 swapped 88 starion
Round 2?
There an absolute shit ton of 3052/ GT3076 cars with slips on this forum. How can't you find any info?
Jesus, even half the dyno sheets actually show a log of boost!
My first Idea, after I just read that it is basically a FP3052, would be to go on forcedperformance.com, click on dsm, click on turbochargers, and click on 3052.
This is a common dsm turbo, lots of people have run them, lots of people have written about them. It's very easy to find information about them.
How do you plan on getting this contraption your planning on building to run, if you can't complete a simple research task? Are you going to post on here about basic wiring, when you run into trouble with that?
I run the fp3052 and I hit full boost at 4100 rpm. I have a 2.3 stroker and 272 cams
I ran a 3076r on a 2.4. 1mm oversized valves, ported, 272's, Magnus SMIM, custom 3" O2 housing. Made full boost by about 3800 give or take and made 452whp on E85 with a pretty conservative tune.
  • Posting a new thread asking if anyone is using one of the most common ball bearing turbochargers on the market. (LULZ)
  • Starting your thread in the Newbie forum despite being a proven member who should be setting examples for others by using the correct tech forum instead of the one that gets the most traffic.
I could go on, but instead I'll just move the thread into the correct forum and go from there for a while. If it goes down in flames, it will be closed / deleted. Work on your capitalization, sentence structure, and spelling a bit while you're at it. :thumb:
