FWD GST swap to a AWD GSX? Basic [Merged 2-07]
Xain10229
Dec 17, 2002
Lewisville, Texas
POST ALL OF YOUR BASIC QUESTIONS HERE.
1) Yes, it's possible.
2) Yes, it requires some basic cutting and welding.
3) Read through this thread before asking any questions. And read through this article written by Jacob Isaac-Lowry.
4) If you're serious about specific parts of the swap, and/or you're in the process of the swap and you have specific questions other than "is it possible", then please post in this thread.
-99gst_racer
____________________________________________________________________________________________________
I was just wondering how hard it would be to convert my 1999 GST into an AWD GSX or if its even possible. What all do I need to swap and how hard is it?
We did answer your question, you just don't want to hear the answer.
I believe Road Race Engineering has done this a few times. I believe the cost was somewhere in the Neighborhood of 10k after it was all said and done.
HAVE YOU FELL OUT YOUR TREE!!!! I have 400 dollars in my COMPLETE SWAP you just have to look in the right places, now with that being said, pull your tampon out roll your sleeves up grab a wrench AND DO IT YOUR SELF there is much more glory to doing it your self than buying it, I BOUGHT MY FWD just to do a AWD swap to prove to people like you it dont cost 10k 8k not even 1k to do it pull your head out of a dealership manual and click on Searchtempest.com and search thats all
Keep in mind that you quoted a post that is going on 7 years old. Back then, a clean 2G retailed for over $12K, so naturally, the parts to do the swap costed more as well. Not to mention the shop's labor rate...
i have a few questions about a swap for my spyder gst. i would like to swap my 99 gst spyder to awd in the future and the perfect opurtunity has dropped into my lap. i foud a gsx with a blown motor. It is a full car except for the blown evo 9 motor. so it has everyhing i need except an awd manual transmisson. so this would be my plan. pick up the car and swap it out. i have the space to do this. then i could bolt up my gst's gas tank, suspension and tranny with it. so then i could sell that car only needing a new motor. what i nee to know is what are the problems with this swap? is there anything i need to know? he is asking 2,000 for the car but i would low ball down to 1000-1500. does my gst motor mount up to the awd gsx tranny ok? will it being a spyder hurt anything? i know i would need a different flywheel and a clutch, anything else? thanks for any imput.
I don't mean to sound like an ass, but did you read the link that was in the first post? It has a list of everything you'll need to do the swap. Your GS-T motor will work fine with the GSX tranny, it's no different than a GS-t coupe. You can't use your gas tank, you have to use one from the GSX. And how did the owner of the GSX fit an EVO 9 motor in it? That motor won't fit in a 4g63 equipped DSM without MAJOR fabrication.
GSX Spyder Conversion
Can I do this swap using the following parts.
1) I am allready in the process of swapping in a 6 Bolt engine.
2) parts list (I allready own all this stuff)
1991 Eagle Talon TSi AWD Shell
1991 Eagle Talon Shepracing Stage 3 Rebuilt 5Spd
1991 Eagle Talon Transfer Case Shepracing rebuilt
1991 6 Bolt AWD Flywheel. Fidanza
1991 AWD Front CV Axels
1991 Drive Shaft
1991 4 Bolt Rear End
1991 Rear Subframe
3" turbo back Exhuast from 1991 Talon
1991 Talon Gas Tank w/ Walbro 255 LPH Fuel pump in it.
1991 Heat Shield and Straps
So Basically I want to know if the 1st gen stuff would be swappable with 2nd gen stuff or does the subframe change dramatically between the generations? If it is possible I will convert my car to AWD if not I will sell this stuff and get a rebuilt FWD tranny.
Thats what I was afraid of. I have literally never seen a GSX where I live. They just don't exist.
I had to go out of state to get my GST.
Loads and Loads and Loads of 1g cars. Every 2g is an RS or GS with the occasional GST. Very Seldom though.
ok i dont know if this is the right place to ask this but i need to know. i want to do the swap on my 97 m/t eclipse. i have a 96 awd a/t talon laying around with no engine tranny and is far from running condition. i have all the parts for the swap except the transmission. my question is can i use the trasfercase or is there a differece in auto and manual transfercases? and will i need a 97-99 m/t trans or will any trans form 95-99 work?
99gst racer i was wondering how u like ## awd system? any drawbacks to doing the swap? do u wish u had bought a gsx instead? thanx
I love AWD. No drawbacks other than a bit of labor.
No, I don't wish I would have bought anything else instead of what I built. It was a great learning experience to boot.
Thanx alot bro im glad it worked out for you!!! Im very seriously thinking of doing this swap to my gst. I want my gst to be a gsx in the worst way LOL:D
hey guys, new member here. does anyone know if the suspension and drive-train from a 1G AWD is the same? i'm wanting to do a FWD to AWD swap in my 98 talon and can get a 1G parts car for dirt cheap
