2G FWD fuel pump hanger modification for DW200 pump and STM 6AN - barb fitting
so the DW200 pump is a little longer then oem so the lower bracket needs to be lowered down a bit. As you can see half way up drill a 5.5mm or 6mm hole for the new location and this way you will have a small amount of room for it to not foul the pump hangers nipple. Its the most logical way to keep the lower bracket installed otherwise its a jubilee clamp which i did not want to use.
I hate to necro an old thread but I had no trouble with fitment in my 95. I simply pulled the O ring out of the hanger and fitted it to the pump nipple on top of it's seat before stuffing it back into the hole on the bracket and it works just fine. Seemed to fit just like the factory pump did. Is this a normal thing or should I have had a harder time of it?
When you use a bulkhead like pictured, the factory seat wont work. You cut it off and drill a hole for the bulkhead. This is most common when upgrading feed and return sizes.
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
  • For sale 2g 2G Auto Shifter Base
    2G Auto Shifter Base $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 1g Mishimoto radiator
    Mishimoto X-Line Aluminum Radiator | 1990-1994 1G DSM (MMRAD-ECL-90X)
    • william
