fuel system suggestions
Hmm, I think I see what you guys are doing. I just did what I thought was logical. I ran the -8an feed line to the passenger side of the rail (with an -8an fitting welded on) and then I welded a -6an onto the other side (because that's where my AFPR and stock line is run) for the return. Don't mind the crappy welds. I tried to braize this one together and it didn't work :shhh:
MB
Ah, I see. That's basically how mine is run, just no fittings welded on, obviously. I'm guessing that is a 95' fuel rail, cause my test port is on the passengers side of the fuel rail.
That's how I was picturing your rail, sometimes words just get confusing.
Sorry guys, I didn't mean to throw you for a loop on this one. At the time, I measured out the ID of the stock line and it was just a hair tick under the line that I was using (just slightly smaller). So it would be considered -6an. But that's what I meant by being"smaller".
For most applications -6an would be enough. When you start looking at above 400whp, I would go with -8an.
Just would like to make a correction for future reference.
After a discussion with a few other 2gnter's....
The ID of the stock line is 5/16, the OD however is 3/8.
Making -6an a good size upgrade and IMO would be able to flow enough for the OP's 450-500hp.
Making -6an a good size upgrade and would be able to flow enough for the OP's 450-500hp.
Hmm, I'm not sure if that was directed at my previous posts but I thought I was clear on my description of what and why I did what I did. I give you all that long ass post so that you may understand my thought process and make your own decision. I think I made it clear at the end of my post about my position;
As for the lines, refer back to the dual walbros. -8an is safer than -6an.............. Keep in mind that (I believe) the stock line is actually less than -6an (I use the stock line for my return line). But I would be comfortable with -6as a fuel line.
Just my "IMO"
MB
And I understand that you spoke to some "other" 2gnt'ers and I'll respect their opinions. But I'll stand by my assessment because I actually measured my stock line ID and it was again, just slightly smaller than the ID of my -6an line that I was using (the measurement was in metrics and, no, I don't remember the numbers, LOL). Hey maybe there's something funky about my line but that's what I saw.
So call it a "correction" if you like. I read it differently :|
MB
Mark I will never trust another number, measurement, or any piece of advise from you again. Credibility = 0. LOL
When you originally said 3/8" on the stock feed I expressed my opinon that I thought that was rather large. I have a -6an return line and the stock feed line. When I get home I will try and take a picture of the two side by side (weather permitting), but I'm pretty sure you will notice a size difference between the two.
I'm not trying to start a argument and I respect what you think about needing -8an. I was just about 100% sure that the feed wasn't 3/8" and I don't want a bunch of people in the future to get the wrong idea.
You've been doing this alot longer then most of us, but IMO I think -8an overkill. But, to each his own.
Edit: Mark something just came to mind... Where exactly did you measure the stock line when you got 3/8"?
Hmm, generically a 3/8" line is considered -6an. I currently have a -6an line connected up to my stock line (using the stock fitting). I don't think I put any info out there that said I measured 3/8" but what I did say was that I measured the ID of the line for -6an that I attached, versus the stock fuel line and found that the stock line was just slightly smaller than the -6an (slightly, again I measured in metrics and I don't remember the numbers)
Too late. You and I are throwin' down now! Just give me a minute to get up out of my rocker :p .
Naw, no problem here. I'm just giving my opinion and reasoning and allowing people to make decisions of their own accord. Sometimes that can conflict with others ideas. I got no problem with that :)
.....and I respect what you think about needing -8an....... but IMO I think -8an overkill.
I think in my post where I elaborated, I pushed the idea that I did -8an as more of a safety net (and a precurser to more power - as Ajax pointed out) than a necessity. I would not say "needed" is what was meant (as I pointed out in the previous post)
And Ryan, just so we don't get any "internet miscommunication", its all good :thumb:
MB
Oh wait a sec (as I edit like you just did), I'm measuring the line at the firewall, are you measuring at the rail? THAT would explain the difference. I didn't consider the rail as a measurement spot because I put on the fittings etc.
Ah, maybe that's it!
So for 450whp, ~6an lines would work, not is that for both the suplly and the rerurn. Also, where is a good place to get SS fuel lines? Thanks, all of you input is really helpful.
Just my "IMO"
MB
I feel so "impotent" quoting myself :p
That would be for both feed and return line. As I said, I err on the side of safety for fuel components. That's a reason's I run -8an feed line.
MB
Sorry I subconsciously converted.
And I think this is what I missed; that you said it was more of a precaution and I totally missed what you said about being comforatable with -6an. I also forgot that you are aiming a little higher then 400hp :). Sorry for my lack of reading, LOL.
I'm pretty sure that's where the miscommunication is.
Well, I'm glad we got all that cleared up. :)
  • For sale 4G63 NEW Stop Tech Drilled And Slotted Rotors
    New Stop Tech Drilled & Slotted Rotors $70 + shipping and paypal fees* FITS * Eclipse GST...
  • For sale 2g 2G GSX/GST Manual Transmission Steel & Poly Mount
    2G GSX/GST Manual Transmission Mount (Steel & Poly) $45 + shipping and paypal feesYou must be...
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
