fuel system setup on a evo 3 16g
dsmaniac
May 16, 2006
Ravenswood, West Virginia
What is the best fuel system setup for a 92 talon tsi with all supporting mods and a evo 3 16g
like what fuel pump, injector size, etc...
I run a rewired 190 and 650's. Gets everything I can from the 16g. You can also get a 255 but then you need to get an AFPR.
-Mike
Are you ever plannin on upgrading to a bigger turbo?
I thought about upgrading to the sbr bastard 20g it has the 16g housing with the 20g internals. probably get the tdo6 turbine if i get this turbo.
I plan on upgrading at some point down the line, but for now am running an EVO III with a 255, AFPR, and larger injectors (run something larger than 550s at least if you plan on maxing this turbo out).
Keep in mind that you may need an AFPR with a 190 Walbro. My suggestion for the Evo3 16g is at least 650cc injectors, a walbro 255 or supra fuel pump, AEM FPR, and DSM Link. You should be able to pull on the positive side of the 300whp mark with that set up. (with tuning, of course)
