Fuel rail help.
That's exactly what I did to mine. Don't buy those expensive adapters unless you plan on going back to stock some day. Tap, install with tephlon sealant and call it good.
:talon:
Here's some additional information with the Tap sizes people have used and good sealing advice for the fittings.
http://www.dsmtuners.com/forums/newbie-forum/285363-1g-fuel-rail-tap-size-afpr-setup.html
Ahh I remember coming across that thread when I was searching to tap my rail.
I tapped mine with a 3/8 NPT and used the following NPT > -6AN adapters from summit ith a little ARP thread sealer:
Adapter
Here's an easy way to adapt -6AN to your stock fuel filter to get rid of the banjo bolt and make a nice feed line:
From Summit:
Mikuni Carb Adapter - Replaces Banjo
-6 AN 45* - Then run your braided line to another -6 45* on the inlet of the rail.
You can go a cheaper route and use a NPT to AN 90* adapter on the rail inlet as well, but it really only saves you a couple bucks. :thumb:
Thanks guys for the help. I ended up just buying two 6an weld ons for like 3 bucks each and took my fuel rail to a local guy and welded the fitting onto the rail for only 10 bucks. so instead of spending 54 or almost 60$ for two little fittings. I paid around 16 dollars. I am like most dsm guys always broke due to having to buy parts after parts LOL.
