fuel pump
Mrdrd_Laser
78
Mar 23, 2009
Memphis, Tennessee
Ok, the previous wner of the car told me he had a 255lph pump in it. Is there anyway to tell without actually taking the pump out? I figured the 255 would make more noise than the stocker but I cant even really hear the fuel pump. I dont want to run more boost and lean the motor out with the stock pump
Hooking up a fuel pressure gauge and checking for overrun could give you a vague idea of if it is an aftermarket pump but not exactly which one. Pull it out and check.
There would be no way of telling unless you supplied the recommended voltage for these pumps at full duty cycle and ran the pump for 15 minutes. You would measure what the pumps output would be but this would be tedious.
Just turning the key and trying to measure would be inaccurate due to the fact you don't if the previous owner did the rewire for the pump, this would dramatically affect the pumps output. JMO
I've got a logger and everything so if I run it lean I can back the boost off. I guess i'll just pull it and check.
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
  • Wanted GVR4 3000gt vr-4 gen 1
    Looking for a 1st generation vr4, preferably 1993 due to the 25 spline output.
    • Pressterra
