Fuel Pump?
AMPPRC
114
Sep 30, 2008
Desoto, Missouri
i was at the track on Friday my second run my engine shutoff. when i got it off the track i tried starting it up. it wouldn't start. i opened up the hood to check my wires that where going from the battery to the fuel pump. it was disconnected. i reconnected everything but car still wont start up it just turns over and thats it.checked the inline fuse that i put in between the battery and the fuel pump its not blown. is there any other fuse that could of blown? or would it of made my fuel pump go bad bad?
you installed a add on pump or replaced your stock one??? you wired it yourself???? just trying to clarify.
did you check all your fuses under the hood and under the dash???
Cheek the relay you used for the rewire also all the connections going to the relay. Make sure there all tight. I've had a nightmare of a trip one time cause of that. Since then all on those connections have been soldered and i've been fine ever since.
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
