Fuel pump O cap won't screw on...
Kdouglas89
436
11
Jul 8, 2013
Davenport, Iowa
I was having all the issues in the world just removing fuel pump with rusty fuel lines. Finally broke lines free, assembled fuel pump.
I placed the rubber grommet over the fuel tank ring, and kept trying to just screw the cap on and it doesn't seem to want to. Is there some sort of truck to screwing this cap on haha? I feel dumb.
Had the same problem wouldn't thread and popped off. Buy a new rubber seal and rub a little oil on it when installing.
Same thing, seems like it's popping off. The seal seems fine, sits pretty nice. Will try some oil or something tomorrow.
Any other tips would be greatly appreciated!
Thanks
So the plastic sealing ring that threads onto the tank is stripped?
The thing you have to ise a hammer and flat head to remove?
The plastic ring yes. I am not sure if its stipped, its just being a pain in the ass! Like, its hard enough trying to screw it in solo, let alone with the pump assy attached. Seems like everytime its tight, I hammer it, and it slips off.
Anyone have a link to a new plastic ring? Been tryign to look for one, but no luck.
  • Wanted 6 bolt NT water pipe
    • chrisman287
