fuel pump cap and O ring
Buy a walbro install kit from like extremepsi or whatever vendor. I had to do the same thing. The walbro cap/oring/etc all fit on the stock pump too.
I have the ring you can have for free if you want to spring for the shipping. Should fit in a small USPS flat rate box. PM if I can help.
the little cap is also cracked. does that have anything to do with sealing? or would all my pressure loss problems go away with the new ring?
i can send you shipping by wednesday. ill pm you later from work
Definitely need the cap too. Mine was cracked when I bought my 1g (non running), and it wouldn't build enough pressure to start.
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
