Fuel pump 190lph or 255lph?
bluelsr90
95
3
Aug 3, 2005
petersburg, Virginia
Have a 1g with a 16g turbo looking to run about 15 to 18 lbs of boost. Should I get a 190lph or 255lph fuel pump?
I would go with the 255 and a afpr incase you change your mind and want to go faster :)
This is a good idea. I got the 190 and changed my mind and got the 255. make sure you get the afpr. But its perfectly fine to get the 190 for your goals. The pumps are pretty similar in price but the afpr is what jacks up the price.
I went with the 255lph until I got bitten by the 500awhp bug. You should do like I should have just went with the Areometer 340lph and should support all needs.
Basically get the 340 and you won't have to upgrade later...
Op is only running a 16g...255lph is more than enough. If he is going to go bigger than 500hp then sure get a 340lph or something. Just my opinion.
if he plans on running over 500 hes gonna need to upgrade alot more then the fuel pump LOL, for a 16g i would say 350hp on a 255 is a very realistic goal
