190lph fuel pump
slow_talon
144
Jul 8, 2004
Brownsville, Texas
first of all i have a 2g talon tsi. Currently i'm running a 14b and other bolt ons I bought a 190lph fuel pump a while ago and i was wondering why i can't boost past 16 psi that's the same i used to boost with the stock pump so what would the problem be? do i have to buy the rewire kit? or a fuel pressure regulator? or is there another way? i just want to at least boost 18psi or so so that the front mount will help :cry:
14b @ 16psi
turbo xs mbc
190lph fuel pump
blitz bov
2 1/2 downpipe
2 1/2 exhaust
upper intercooler pipe restriction off mod
2 1/2 j pipe
front mount intercooler (not installed)
soon to come:
Are all the lines hooked up right to the MBC? Do you hit fuel cut after 16psi or does it not go past 16 psi? More info would help. I run 18psi easy on a t-28 with a 190f/p... you may have major boost leaks. Check all the piping couplers and BOV flange.
i can't go past 16psi i have the stock upper pipe with the biltz bov mounted with a custom coupler and all the other pipes are ok. so it might be the coustom mount on the blitz
That is what I would think, custom mounts tend to leak, at least for me. I have a good idea tha the one I use for my 1g bov leaks. That would be my first thing to check.
