190LPH or 255LPH???
neuralracing
770
Jul 16, 2003
San Juan, Puerto Rico, Central America
How do I decide wether I should buy a 255 or a 190? I know that if I get a 255 I need to invest in an FPR. I am a fan o buying things once... so if 255 with FPR is the way to go... so be it... but if 190LPH will do... the its cool as well. My plan is to run the most out of my 14B and then upgrade to a 16G or something bigger while maintaning the quick spooling capabilities of the 14B (Autoxing and Track Coarse car).
With the 190... what injectors should I use to get maximum boost output (safely)?
550cc will work for both the 14B and 16G, however if you're going with an EVO III, get 650's for a little more headroom and a lower IDC.
Hope that helps,
Andy
normally i'd say "get the 255 just in case u wanna upgrade to a bigger turbo later on", but theyre so cheap and easy to swap than u mine as well get a 190 for now so u wont need an afpr
