fuel problem
Aproductions
2,123
50
Aug 11, 2009
Allentown, Pennsylvania
So I just bought a 96 RS and it is leaking fuel somewhere under the throttle body.
Is that side the fuel return side or the filter to rail side.
When I looked at the rail it looked like a line just came off of the rail and stopped.
Can someone take a picture of the area I am talking about and the path of fuel?
Thanks.
I just explained it and I won't be home till tomorrow. I am trying to see what is wrong so Ill know what I need to do. I don't know what it is SUPPOSED to look like.
Someone just post a picture of the fuel path on the right side of the rail and I will know what the problem is.
Thanks! maybe it is the fuel rail test port? There is like a 3" line coming off of the rail area that goes to nothing.
Possibly got a 95 fuel rail and they tried to block it off (and that's why its leaking).
The test port is an actual shraeder valve (like on a tire). It comes comes directly off the fuel rail (a little nipple thing that usually has a twist on cover).
The 96 and up have the FPR back by the tank. Do you have an FPR on the rail?
MB
Bullet, Yes on the left side of the rail.
on the right is the problem (see picture) and so your saying that I need a new rail? also what do I do with the FPR? where would the left side of the rail go?
