Eagle 5
- 380
- 3
- Jan 26, 2003
Cincinnati,
Ohio
Ok, Ive been trying to get my fuel trims to level out and it seems I can't get them to do much. Heres the problem.
I have ak eydiver stage 3 chip compensating for the 660cc's etc, all that fun stuff. I have emailed Jeff and he has checked over my chip and says that it is all correct. Basic setup is 255 hp pump, 660's, afpr, MAFT with 3" gm sensor.
My problem is my base fuel pressure is up around 50 psi, and I have the mid knob turned up to +35% fuel... and I still can not get the mid and high trims down. They were pegged at 139 but I did finally get them to move down to around 137 mid and 131 hi. I can't add anymore fuel on the MAFT and I dont want to turn my fuel pressure up anymore, I already don't like running it at 50 psi base when it should be at 37 psi base. I'm sure my afpr and fuel pressure gauges are fine. Couple questions though
- could my fuel injectors be so clogged they are causing a problem? Though when I had the VPC in it, my car was running waaaay rich. Thats why I dont think its the injectors.
- Is it possible I was sent a 2g maft instead of a 1g maft or is there some way I can check it to see which one I have? Maybe the wrong one was sent or heck, maybe I clicked the wrong button back when I bought it but I'm sure I didn't and I still have the receipt for it
I have the MAFT set to the 3" gm settings. base injectors set to 430cc trying to help with the fuel.
Any ideas? Is there a way I can check to make sure I have the correct MAFT? Also, if someone can tell me which of the 3 wires go to the connector which connects to the air sensor from the MAFT I would like to know. I extended my wires so I could mount the unit in the car. Maybe I somehow mixed the wires up because I believe there are two grey wires and maybe two brown wires. Thanks.
Also posted on fullthrottletech.com, hopefully someone maybe has an idea that I dont have or has had a similar problem
Thanks
