Fuel Cut on 1G AWD
1993-Talon-TSI
33
Nov 12, 2002
New Hamburg,
Is there any way to modify the MAF on a 1G, to eliminate the fuel cut, besides just removing the bottom screen-mesh. I have removed the bottom and was able to run upwards of 21 psi but now that i have put a fmic on the flow has increase due to the increase volume of the intercooler and piping. no i can't run like past 16 psi without the fuel cut hiting???? is there any cheap way to eliminate the fuel cut completly, i have enough tuning devices to monitor the fuel cut, so i can go withiout it and be safe.
It is the worst thing when the engine can run at 21 Psi but the F*&^% computer /MAF won't allow it. also the problem seems to get worst as it gets colder out???
Any help would be greatly Appriciated.
Thanks :dsm: :talon: :laser:
Colder=more air.
Are you Positive you don't have any boost leaks after the new FMIC Install? A boost leak is the main reason why people hit fuel cut early.
You might want to think about switching to a 2g Mas setup.
Sure there is. First, make sure you have no boost leaks anywhere (IC piping, BOV, T/B shaft seals etc.) You can hack the MAS a little bit more by backing out the screw and or even dremel the area where you took out the lower honey comb so it looks like this -->D with the flat part facing up. :thumb: No fuel cut but I hope you have bigger than 450cc's (+ auxilliary fuel control) and you may get idle problems. On my MAS last year, I completely cut off the lower section. OMG :thumb: It pulled like crazy and idled just like stock - just make sure you don't run too lean and have a backup MAS just in case you f*ck up somewhere with the hack. ;) One of the sensors is located on the bottom portion of the MAS so be careful not to break it or saw it off. :D
CanadianTSi said:
Colder=more air.
yep :thumb:
just get rid of that 1g maf
