Fuel Management System Setup
ReDEcLiPzPiNoY
38
Feb 4, 2003
Bartlett, Illinois
Hey Guys
I have a 97 Mitsu Eclipse GST. Im planing to install a small 16g w/bullseye power turbine housing. Im also planing to buy the Fuel Management Bundle from ExtremePSI and wanted to kno if the FIC 550cc Ball-Style and the Walbro 255 liter per hour Fuel Pump is a good setup? OR should I just get the FIC 550cc Ball-Style and the Walbro 255 liter per hour High Pressure Fuel Pump? OR the FIC 550cc Ball-Style and the Walbro 190 liter per hour Fuel Pump Rewired set up? Im trying to atleast hit 22psi. Which setup is better?
Thanks
ReDEcLiPzPiNoY
I personaly aim hi- then turn it down from there.
255 lp is fine (even re-wired)
255 hp stock wireing is fine
and 255hp re-wired with FPR is fine.
