Fuel filter mounting location
I placed mine in the oem location. I used the bracket that came with the "818" kit. The only modification needed was too bore the holes in the bracket slightly larger to fit the oem bolts.
Yea no problem. Here is how i mounted it. I believe it was the factory location. If not, right near there, there was two equal sized bolts side by side that i used. The holes in the bracket were just slightly too small.
I just did my tank to rail and here is my new location. What you think?
