2G Front roll Torque Solutions Mount not lining up
mx3baker
109
44
Apr 27, 2017
Topeka, Kansas
Any ideas on getting this mount to line up with the holes on the cross member? I have tried mounting the engine mount and "rolling" the engine up and down, but it never actually lines up. Also have tried the other way, run the bolt through the engine mount and pulling or jacking the engine up a bit. Still no luck.
Those are pretty bad to line up, I damaged my shoulder trying to lay under mine and tighten the bolts that go through the crossbar, its just an issue with the bolt holes on those brand of mounts apparently, I was also wondering if anyone else had issues with them and figured it was just me, they are tough, honestly though, the last mount to be installed is probably going to be tough anyway when they are almost solid motor mounts.
