front right tire camber......help
Stizzyflip611
85
Nov 21, 2003
Howell, New Jersey
hey guys,
i bought a 92 Laser AWD, and when i got the car the front passenger side tire was off the rim. yesterday i bought a set of 16" talon swirlies wit tires on them and put them on the car. the front passenger tire doesn't look like it is sittin on the ground correctly. the top of the tire is tilted outward (positive camber??), so i checkeed it out and the stabalizer link that attaches the sway bar to the lower control arm is bent. my question is, would that throw the camber of the tire off, or do i have a bigger problem, like a bent lower control arm or a bent spindle hub?
so if i got that answer correct: most certainly and most likely a bent lower control arm.
Thnx luv2rallye
any other ideas from u guys?
