Resolved Front case gasket
SNAKE_15
571
48
Aug 28, 2012
Bakersfield, California
Couldn't find an answer so I thought I'd finally ask. If I'm replacing the oil pump gasket and rear main seals for the front case, does it have to be oem or will a felpro one from AutoZone be fine? I paid too much for these gaskets at the dealer and the ones from AutoZone are half cheaper.
Most seals/gaskets from a reputable manufacturer (known name brand) should be fine. Federal mogul- felpro is a major supplier and it would't surprise me if 75% of all brands of gaskets and seals comes from them.
If your going through the trouble of replacing the oil pump gasket then I would say your list should be alot longer on what needs replaced.
If it was me I would also do
New Oil pump, water pump, timing belt, timing belt tensioner, timing belt idler, probably replace cam seals, Your car looks like a 95? if 95 I would replace the cam and crank position sensors as well or swap it to the 96-99 configuration.
I might trust a used OEM oil pump if it was putting out great pressure before. the other stuff I would likely pick Gates for water pump & timing belt. Tensioner would be OEM. Fel pro for cam seals. Maybe look over what rock auto has for idler and sensors.
