Front and rear main seal. need help asap...
packinkimber45
378
3
May 26, 2006
Boise, Idaho
Hello guys, I wanted to know what everyone thinks about replacing the front and rear main seals. Are they parts that I should go with oem, as far as buying from the dealership? If I order through let say schucks (felpro) would I be good to go? Just got my motor out and decided to do the main seal also. Thanks.
Shucks... *cough* - don't get anything at Shucks when it comes to DSM's.
Fully agree: Head to LHM Mitsu on Fairview and get you some OEM seals (Original Equipment Manufacturer), or if you want, NAPA is a good 2nd choice..even BowWow Auto on Orchard isn't bad either .....but never Shucks!
good luck-DSM
Decided to go oem, might as well since I have gone with lots of oem parts that will be going in soon in the talon. Should I replace the rear main seal ring also? Thanks for all the responses.
Dunno about the rest of you guys but I always put a thin coat of black rtv on the outter edge when I put mine in....cause I've had leakage issues otherwise. Just a word of advice.
