FPt28 Rebulid it or replace it???
eclipsers97boy
96
Jan 8, 2009
Providence, Rhode Island
Ok so i have a fpt28 w/minor shaft play, good turbo but i can't keep the intercooler piping on it(previous owner cut the cold side). I called up forced performance and they said $650 at most plus s&h as long as I supply a new housing. Here's a link to a pic of it: 1995 Mitsubishi Eclipse GST Photo Gallery - Photo 20 of 59 by LACH!!! - MySpace Photos A brand new one is $900 with no core charge. what's u opinion on What to do? thanx:confused:
IMO..Forced Performance may be a little pricey, but you cant deny the quality of there turbochargers. They are pricey , but its for a reason. These turbo's are proven. On the other hand there are other proven turbo's also like stated above..the EVO III 16G. is one of them. IMO its also a sick turbo that can be beat on and beat on at almost twice the factory boost while maintaining reliability. Its your money. Its up to you. Does the FP T28 outway a EVOIII? Maybe you should upgrade to something bigger and better. :sneaky: If my FP3065 ever goes boom, Im deff. stepping up the game. Good luck my friend:thumb:My rule is ...UPGRADE..NEVER REPLACE!!!!
You can get 400 w.h.p. on the EVOIII 16g for $550. Or you can buy the 68HTA for $850 on sale. And it would be at like 430 w.h.p., so its up to you if the extra lag and money is worth it. For me, I'd barely notice +30 h.p. at this point and another $850 for +30 w.h.p. would make zero sense. For you stepping up from a T28, maybe would make some sense.
going with the evo3 extreme psi has it for $768 with the install kit!
Sounds about right, mine installed was like ~$750 or so. I used a stock 1g oil feed line feeding off the cylinder head, filed the 2g oil return mounting holes a little wider, some new crush gaskets and oil return gasket, and a 2" j-pipe, and some bending of the water lines and some extra rubber coolant hose (i.e. fuel line hose) to get everything fitting right.
