Fpr mandatory???
highintenzity4
221
Apr 30, 2004
Mission, Texas
Been hearing that fpr arent really worth it if I already have the dsmlink... Running a 60-1 setup would I need a fpr? Thanks. :dsm:
Dsm link has nothing to do with needing a fpr, the turbo your running only indirectly determines if you need a fpr-it's what fuel pump you use. And yes, you should get a fpr since any fuel pump that can support a 60-1 turbo will over-run the stock fpr.
Exactly.
If you are going to run that turbo where it should be run you will need bigger injector. To supply the big injectors you will need a big fuel pump. That big fuel pump will over run the stock FPR. So get all three: injector, fuel pump, AFPR.
Yes, regardless of your tuning programs, anything over a 190lph pump should require you to do a FPR w/ out running pig rich. DSMLink won't help the richness at idle so the FPR is needed.
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
