FPR install Help
Mitsu725
211
Mar 22, 2004
DAVIE, Florida
Can ne one tell me how to install the aeromotive fuel pressure regulator i searched vfaq and couldnt find ne thing, its the red inline one not the one where u cut the stock one the other one cause i dont know how to hook the lines or ne thing up and also can u tell me what i need like fittings or whatever??
http://www.flyservers.com/members4/autoalchemy.com/catalog/DSM_0001_FRIA.html
You could use one of these fittings because they seem to help some.
http://www.extremeturbo.com/fpr.php
A nice article.
http://www.roadraceengineering.com/instructions/bm-fprinstructions.htm
FPR Install instructions.
http://www.roadraceengineering.com/instructions/bm-fprgaugeinstructions.htm
Gauge install instructions
From ROAD RACE
B&M CommandFlo Fuel Pressure Regulator
B&M has designed a great new option for getting a little more safety margin for cars that are running a little lean. This adjustable fuel pressure regulator will allow you to raise the base fuel pressure to richen things up. You install the CommandFlo by cutting off the top of the stock fuel pressure regulator and bolting on the B&M unit. Only the upper section that holds air pressure is modified and not the lower section with fuel pressure. Once installed, you can raise the pressure from stock but not lower it. While additional fuel pressure can buy you some safety, bigger injectors may still be needed if you are running high boost.
