Found cut wires explain!
He has a 2g with a 95 7bolt motor still, judging by the thermostat housing. Im assuming that the CAS is just there to plug the valve cover becuase there should be a circular seal there, assuming someone lost it and just stuck the CAS there to plug it. As far as the no start. Check for fuel, and spark first and report back.
again, someone probably put it there to block off a huge hole that would of been there if the 1g CAS wasn't there because they lost this part.
MD184946
MD305709
As stated earlier in this thread the car ran without this hooked up sence i bought it. I have put over 3k miles on it with the CAS cut. The 2g use the CPS to do the CAS job if i read it right. I am wondering if i can use the 1g CAS instead of my 2g CPS if that happens to be the reason for my non firing cylinders.
I believe this wouldnt even be in my car stock. A 2g runs off the CPS crank position sensor thats behind the intake cam gear. Im wondering if the 1g CAS can be hooked up to replace the CPS? If so im wondering how?
If it was never hooked up, it would have started before because you still have the stock sensor installed behind the intake cam gear.
