Found cut wires explain!
Just by the look of it i know this is not a 7bolt motor, that cas belongs to a 6 bolt motor. If that is the case i believe you don't have to plug anything there cause the cas is on the other side of the motor. And as the vendor above mentioned, check to see if you are getting spark and fuel, and check to see if your battery is weak, get it tested.
It's not a '95 motor. They don't have the CAS there. It's under the cam gear, under the timing belt cover on '95s.
Unless he's got that CAS there to act as a plug, and he's got the 2Ga CAS still hooked up on the cam gear side of the engine. That's the only explanation that I can think of...
