Cut wires sandrail project
kocherdeal
35
Nov 27, 2010
mesa, Arizona
OK well tried to start the UAV today but found a few wires cut they are the bigger black/white wires coming from the ignition pack and power transistor and another little thing my main question is i have 2 black and white wires that are cut coming off of the mpi relay where do those connect too? and ecu pin number110 wire is cut.I have a feeling they connect together but how?
I can't figure out how to copy just 2 pages of a pdf files but one wire there goes ignition coil/power transistor and I believe it connects to ecu pin 110 through the ignition switch. The wire next to it goes to the fuel pump. It looks like the center one goes to the power transistor and the other one goes the fuel pump. I thought I was better at reading schematic but it has been a while. I'll try and get a pic.
This might help.
http://i1037.photobucket.com/albums/a456/govproperty/schem.png
It looks like the middle BW wire goes to the ignition switch then to the power transistor and splits to the ignition coil. and the other BW wire goes to the fuel pump. Technically the fuel pump check connector first but I don't know where that is. In the schematic, in the link, look at pins 2 and 3 out of the MPI relay. One goes to the fuel pump and the other to the ignition switch on the right hand side. I don't have my car near me or I would check for you. Where is Steve when you need him. He probably has this memorized.
