Flywheel resurfacing question
if there is any blue/black streaks, it should be resurfaced, those are hard spots where it has gotton hot and crystalized the carbon in the steel. the clutch disk can not "grip" on a hard spot.
this is the basic process that will be done, but there is an extra step to maching the 4G flywheel, it has a 2nd cut that has to be done to keep the proper distance between the point the pressure plate mounts and where the clutch disk face mates.
http://www.dsmtuners.com/forums/newbie-forum/341291-how-flywheel-resurfaced.html
if this step it too much, then proper clamping load is not maintained, if too tight, the clutch will not disengage properly
