Flywheel resurfacing
1gAWT
71
May 14, 2011
Lincoln, Nebraska
Can I reuse the flywheel after I change my clutch? Did rub the t case a little, should I be okay to reuse it?
^yes but the clutch assembly was fine, just old. I know you can reuse after resurfacing obviously, I'm asking if resurfacing is absolutely necessary.
If you want the clutch to properly operate, yes it's necessary. The only way to be sure the step height is correct is to measure it. measure before you leave the machine shop. If they won't grab a depth mic and show you then you need another machine shop. If you don't tell them what to do they usually take equal amounts off the surface and the steps but NOT ALWAYS. You are responsible for verifying the height, not them. Their job was resurfacing unless you told them specifically what depth you wanted.
