"Flywheel bolts for a Fidanza Flywheel?" Continued
acemas99
55
Jan 8, 2007
Canton, Michigan
This is a question from the older forum "Flywheel bolts for a Fidanza Flywheel?"
I can't post in that forum... I have been on this site daily for over the past few years, but I usually find my answers through searching and rarely post...anyway.
I recently had some trans trouble, and while I have the tranny out I plan to buy and install the Fidanza aluminum flywheel from extremepsi: EXTREME PSI : Your #1 Source for In Stock Performance Parts - Fidanza Lightweight Aluminum Flywheel : Mitsubishi Eclipse 90-99 Turbo
In the thread shown above, there was discussion of Fidanza flywheels having different thicknesses; some with the same thickness as stock, and others being 4mm thicker. I was wondering if anyone has recently purchased the Fidanza fly from extremepsi (specifically the 7-bolt FWD), and what the thickness was relative to stock. I am trying to figure out if I need the longer flywheel bolts or not. If it is the same thickness as the stock flywheel, I am not going to get the longer bolts, but if it is thicker I will get the longer bolts.
Just a side note on this:
We typically keep these in stock, and current pricing is:
MD760086: $5.91 (7-Bolt Cranks)
MD952138: $10.02 (6-Bolt Cranks)
MD008839: $2.19/each
Before someone asks---All I can think is that the price difference between the 6-bolt plate and 7-bolt plate is that Mitsubishi likes drilling holes and charge extra for being denied the pleasure of one more. :shhh:
    • george bromwell
    • pma1123
    • Sdcryan1
