Fidanza flywheel vs stock bolts
Afroclipse
898
Dec 22, 2006
Houston, Texas
who is using them, how much torque did you use, how long have you been using, and how much abuse.
I need to know because mine came loose like a magnum condom on a new born within 20 miles.
On my current setup I bought bolts from Slowboy which I think are 2g auto bolts or something. Heavy duty Loc-tite was used and about 100ft/lbs.
I have used regular 1g 5spd old bolts before with a Fidanza with no issues with the Loc-tite
I reused my stock 1G bolts and have over 5K miles on the flywheel with zero issues. I used RED Loctite and torqued the bolts to 100ft-lb. I have a Fidanza 3.2 clutch to go with the aluminum flywheel and see 25psi on a daily basis. Your bolts were not torqued properly using red Loctite if they came loose that quickly.
I torqued them personally but when I had to change my clutch for an ACT I had a shop do it for me, when it came back it ran for a day or two then wouldn't start. I have everything pulled apart and just ordered the FP long bolt kit.
