acemas99
- 55
- 2
- Jan 8, 2007
Canton,
Michigan
This is a question from the older forum "Flywheel bolts for a Fidanza Flywheel?"
I can't post in that forum... I have been on this site daily for over the past few years, but I usually find my answers through searching and rarely post...anyway.
I recently had some trans trouble, and while I have the tranny out I plan to buy and install the Fidanza aluminum flywheel from extremepsi: EXTREME PSI : Your #1 Source for In Stock Performance Parts - Fidanza Lightweight Aluminum Flywheel : Mitsubishi Eclipse 90-99 Turbo
In the thread shown above, there was discussion of Fidanza flywheels having different thicknesses; some with the same thickness as stock, and others being 4mm thicker. I was wondering if anyone has recently purchased the Fidanza fly from extremepsi (specifically the 7-bolt FWD), and what the thickness was relative to stock. I am trying to figure out if I need the longer flywheel bolts or not. If it is the same thickness as the stock flywheel, I am not going to get the longer bolts, but if it is thicker I will get the longer bolts.
just make sure you use thread lock on those bolts ,my buddy put a fidenza flywheel in his car about a month ago ,within 2 days all the bolts lossened off wrecking his aluminum flywheel ,6 bolt
btw extremepsi is top notch, they answer questions quickly so u could always drop them an email too!
