Fluid change?
CarTrader29
228
Nov 19, 2004
Brooklyn, New York
What kind of fluid do I need to put in the tranny xcase and diff? I plan on using Synchromesh in the tranny but what do I use for the x-case and diff? Are there any how-tos and pics cuz I dont know where the bolts are.
If I were you I would just go spend 10 bucks:confused: on a shop manual, I use haynes, that way you can figure this stuff out quick and when you need it. And trust me, you will need it. ;) Im not sure about what type of fluids though.
I found the info at vfaq.com
Tools Needed
17mm & 24mm sockets
Breaker Bar
Funnel (see Funnel Notes)
6 ft of hose (max 1/2" outer diameter)
3 qts of GL4 Gear Oil (i.e. Redline MT90)
1 qt of GL5 Gear Oil (i.e. Redline 75W90)
Drain pan
Capacities
Transaxle: 2.4 qrts
Transfer Case GL4: 0.5 qrts
Differential GL5: 0.9 qrts
I got confused for a sec cuz of the capacities but then I realized that Tranny and transfer case take the same fluid. Can I use synchromesh for bothe transfer case and transmission?
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
