tranny fluid change
TeeM403
Aug 2, 2012
Calgary, AB, Canada
Okay so im doing a tranny fluid change. I drained it now everyone says it takes 2.4 Qts and you should see it come right up to the fill hole. I put in 3 Qts and i still can not see it. Does anyone know whatsup ?
when i drained it i opened what i think is the fill hole and i could see the old stuff at the top then i drained it looked about right 2.5 qts around there came out. is the fill hole on the side in the front or on the top like almost right under the shifter cables ?
The fill hole is on the front of the transmission on the passenger side case.
