Transmission fluid change
Shipe12
43
Oct 11, 2008
Sinking Spring, Pennsylvania
Ok i did search this question i found alot of helpful info. But none described how to actually put the oil into the tranny. Do you just pour it through the hole where the filler bolt is or what?
Also i noticed you can change your gear oil.
How do you put gear oil into the transfer case and for the rear diff.
Yes, you put the oil in the fill hole. It's easier to get a funnel with a tube and fill it from the top in the engine bay. It'll slowly fill as gear oil is very thick. As for the xfer case and rear diff., get a cheap pump that attaches to the bottle and fill it that way.
Best way to fill the xfer case is if you can take it out and fill i through the tail shaft with about a quart. Put it together drive it around the block a couple times. Open the fill passage on the side and let the excess oil come out. This way u SURE it is all the way full and everything is lubricated.
