fix leaking master cylinder.....broke my rear subframe !!!
Marceldsm
321
3
Jan 13, 2010
Montreal, QC, Canada
So i finaly got my car to run new slave and new master car shifts like butter
know i look at my rear subframe and i can see the passanger side subframe is craked
can it be weelded, or i need a new subframe ?
Pictures would help too. I once had a rear trailing arm that rotted out, it is a long and tedious job to replace and you usually end up breaking other things so I had it boxed in by a welder friend for $80. Has held up great for years.
Dont see why it coulnt be. I would find someone that can tig weld it though vs mig less chance of warping it I would think
less heat effected zone so less chance of overheating and warping the metal since its thin pressed steel. also depends on where its damaged
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
